Old 06-08-2016, 11:19 AM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by xlr8or View Post
A big block with 3.31 gears will be great. If you go with 3.73 in a stroked big block your first gear is going to be useless for anything but ruining tires.
With that kind of torque you don't need different gears. You want to match up the gear set to typical driving speed and make sure the final gear puts the engine at a comfortable RPM. 3.31 gear with typical OD 5th will put you around 2100-2300 at 75 MPH depending on tire size.
Here's a link to a calculator that you can play with gear selection and tire size. RICHMOND Street Performance Calculator
The 3:73 would be for my current setup until I did the big block swap in the future. I run 315/35/17's and would probably use a 3.31 with an OD 5th with a big block. My current setup turns 2700 at 70mph and that is annoying. The .64 5th would give me 2000rpm at 70mph and with the torque of a big block that would be a great cruising rpm
