  #21 (permalink)
Old 06-09-2016, 12:46 PM
fastd's Avatar
fastd fastd is offline
Cobra Make, Engine: ERA FIA, 351W
I think you need to address your power issues before you make a change to the rear gear. You're current set 3:31 and .82 5th gear is fine! Figure out why you wheel hp is just 360 when it should be closer to 500...
At the end of the day, the 3:31 to 3:73 swap really isn't gonna change your life very much; I think you're setting yourself up for disappointment when you should be focused on your cam/balancing out your engine set up.
And don't junk the 427w; it's (arguably) perfect for your car - just make it run better.
Can I get an "amen" Brother Dwight?
