Old 06-15-2016, 05:12 AM
Tenrocca's Avatar
Tenrocca Tenrocca is offline
Originally Posted by Gav View Post
I did drive it on the road as well.
The noise with a top on is less than without.
It was quieter for sure, couldnt hear anything over the sound of me sh1tting myself.
A few small updates - have sorted the windscreen fittings I think. Found that the standard t-bolt coming straight through didnt allow me to get the clamping knob on, so had to put a little bend in them. Not sure if Mr Bruces design changed a bit from the one in the pic above. Made 3 all up. Stainless M5 bolt tapped through a little SS plate and tigged on. Then heated it up with the map gas torch to get a bend.
Pictured below on what looks to be a beautiful piece of brushed aluminium.
Roof feels very snug against the screen. Have some19x5mm foam strip to go between which will attach to the top. Just have a few offcuts in there at present.
Next is the body ferrules and brackets for the top. Need to think long and hard for the placement on these as I do not want to drill in the wrong spot.
