Old 06-18-2016, 09:30 AM
DanEC's Avatar
DanEC DanEC is offline
Dave - My top plate still leaks after re-sealing a couple of times. I straightened the lid flanges and basically tried re-sealing the original gasket. Still seeps not unexpectedly. Sometime I need to try a new gasket. You wouldn't think it would take much to keep 90 wt gear lube from leaking - but it seems to always find a way. I would use some sort of gasket sealer/dressing but I'm not sure what would be best. Lately I've tried Permatex Fuel Resistant gasket dressing with good results. Seems to work better than Permatex #2. Not sure if just lucky or really good stuff.
http://www.jegs.com/i/Permatex/775/8...FQepaQodxJkAXg
At least one of my shift fork seals is leaking also. I put leather gaskets behind the levers too slow it down (which it did) but still get a drop now and then.
ERA 782 Running
