Old 06-20-2016, 08:52 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
If I remember correctly, the other way to tell between WR and CR is on the input shaft, but that would require removal of the trans which you aren't doing. Not sure which is which off hand, but as I recall one of them has a "stripe" turned on the input designating what it is. Dave Kee would know....
I remember determining it was a wide ratio by some other article I read, It was about speed vs rpm between each gear, I remember doing it and determining it was a wide ratio. Unfortunately I suffer from CRS disease and can't recall the exact details. I will try to determine which second gear and count the teeth
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
