Old 06-21-2016, 08:47 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
The available thread at the end of the bolt does nothing more than go threw a hole in the fiberglass, the hole in the fiberglass is not threaded in any way to allow the throttle stop to be adjusted. I suppose you could stack washer upon washer until you achieve some distance you are happy with going the other way requires fabricating a new stop, hopefully you have enough thread left to secure a nut with on the other side of the foot box? I can't imagine making multiple adjustments down inside the foot box, just getting in there to install the throttle stop (or anything else) is a pain in the rear.
