Old 06-22-2016, 05:22 AM
patrickt patrickt is offline
Originally Posted by Bill Bulmer View Post
The filter appears to be about 1/2 inch away from the frame, making removal challenging. Is there any trick to replacing the filter, or any particular wrench type that would work best?
Post a pic so we can see exactly what you're facing. You can usually get them off, but every now and then you'll run in to a car that's had an engine dropped in it and you literally have to lift it up a bit to get to something, like a filter, spark plug, or what not. If that's the case, then mounting a remote filter will be your first real mod... and it's pretty easy.
