Old 06-23-2016, 10:36 AM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Thanks for noticing that. I tightened up that trunk hinge bolt - loose, just like you said.
This is a mechanical secondary carb. I have bigger jets that I can install, but will check the fuel pressure at WOT first.
I have a gauge on the fuel pressure. At idle, it is at 6.5. I'll have to figure out how to mount the GoPro to see what it is at WOT since it cannot be seen it from the cockpit.
