Old 06-24-2016, 01:40 AM
AC Ventura's Avatar
AC Ventura AC Ventura is offline
Cobra Make, Engine: AC Cars Limited, 302 EFI
Originally Posted by Buzz View Post
Its generally not necessary to bend the oval sections around the chassis. They only need to be used under the frame - maybe with horizontal bends in a flat plane - where ground clearance is an issue. Oval to round adapters can be used to transition to header connections and tailpipe sections that need to bend over the rear suspension.
With a car like mine, it's not possible to run 3" downpipes adjacent to the footwells. I just feel there's just not enough space for a practical and serviceable installation. With a 2 x 3 oval downpipe there might be, but no point if you can't get it to transition to under car, where it would have to twist.
I think it's 2.5" or revert (sadly) to some side action.....or run the headers forwards, then loop under the car, so no downpipes in footwells, Only downside I can see, is increased engine bay heat and odd looks. TVR did this with the Griffith and Chimaera, if they are known in the US.
