Old 06-25-2016, 11:49 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Texasdoc View Post
I disagree with this statement: The factory internal bypass is way higher than any normal pressure setting for carbs
Only my pump is set at 7 pounds. It can pump out more but the pumps regulator sets the pressure at 7 pounds at the pump's output.
Now you take that 7 pounds, push it thru a 40 micron filter, along 8 feet of 3/8" hose plus connectors to the pressure regulator. The pressure drop is around 3 pounds, leaving me with maybe 4 pounds when at max flow.
If I had bought the 140 which is pre-set at 14, this would work since the pump's internal bypass would not get activated. But I don't have that pump.
So, I need to block my pump's bypass so it will go above the factories setting of 7, so I can actually get my desired 6.5 at the carb - letting the fuel pressure regulator control the final pressure.
Ah yes, you are correct there.
You have Mallory's equal of Holley's Red pump.
If you can't get the spacer, you could make one, but I would be fitting a heavier spring.
I think it would a safer option to fit a heavier spring?
