Old 06-26-2016, 09:05 AM
wolf k's Avatar
wolf k wolf k is offline
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Doc, simply crank in on the adjusting nut to raise the relief pressure on the pump, this is just going to be a quick test to see if raising the fuel pressure is going to solve your stumble issue.
I have a sense that it is not going to help as your video clearly shows that you are maintaining a visible fuel bowl level even when the fuel pressure drops to 4.5 psi. 4 psi should suffice to keep you bowls full for your 450hp motor. Heck, us Weber guys are running 3psi fuel pressure with smaller float needles than you Holley guys.
I am surprised that no one has commented on your statement that the car nearly dies when taking hard corners, I am thinking these two issues may be related
