Old 06-26-2016, 03:43 PM
patrickt patrickt is offline
Patrick, how much power do you have and how much money do you have in the engine ?
I wanted a "true, honest reading," so I had it dyno'd with the side pipes attached, and water pump cranking. That number was 475HP. If you pulled the engine out and put it on a dyno with open primaries, the numbers would likely be in the low 500's. IMO, a dyno reading that doesn't at least try and duplicate the running condition of the engine is blatantly misleading. As I said before, blykins could probably clone my engine for $15k, or right around that number, maybe less... as I have some overpriced parts in her that aren't really necessary.
