Old 06-28-2016, 09:15 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Originally Posted by davids2toys View Post
Everything is all clean and ready to go back together. actually thinking of skipping the paper gasket and just using the Permatex Ultra grey as I did with the rear end cover. Originally I was just going to put some of it on both sides of the paper gasket as a dressing and Torque it to 15 ft lbs.
If you use the Permatex as the sole gasket, it is a whole different set of instructions per the tube. Tighten until squeeze out, wait one hour and tighten 1/4-1/2 more turns. That is all well and good, but if you have the situation where the threads need to be sealed, I would then think: mark fastener positions, pull all fasteners after the 1 hour period and coat threads with sealer, then tighten 1/2 turn past the marked position.
Any thoughts on this?
I think your are way over thinking it IMHO.
