Old 06-29-2016, 03:43 AM
SydneyChris SydneyChris is offline
Hi Ian... If you are happy with the standard footwell size, pedals, brake mc's and steering column then yes.
You will need a steering column with a collapsible element for a road car. I also built cages around much longer and wider foot wells on both sides. You really need to make a call re the parts and set up you intend to go with.
Personally a bare chassis with the steering rack mounts and suspension pick up points only.. Then delete footwells, firewall m/cylinder mounts, engine mounts and the gearbox mount would be my preference although that may be a bit much for FFR to deal with as far as changes.
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
