A quick check to eliminate the ignition... Hook your timing light up to the HT Coil to Distributor lead, tape the trigger/button to the on position and zip tie it in a position where you or passenger can observe when you run it up thru the misfire zone , strobe light should be virtually continuous, any uneven gaps in the strobe flashs show an ignition fault, if thats all good then you can concentrate on the jetting etc.
Jac Mac
