  #25 (permalink)
Old 06-29-2016, 04:57 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Buzz View Post
Hi Dan - I'm not sure if I articulated clearly - I meant that normally, the axes of the yokes on either end line up parallel in the vertical plane when the shaft is laying flat on the floor as in the pic above. On mine, if the shaft is laid flat like that the yoke on one end would lie flat but the other, instead of also lying flat, would be twisted about 30 to 45 degrees. On one shaft this is a lot more pronounced than the other.
No - I think you articulated clearly - I had a brain fart and not sure where I came up with that 90 deg phasing BS - too little caffeine or something. I agree that that much twist should show some distortion in the tube. Hard to imagine someone would weld them out that much too. My Corvette stub axle was probably only twisted about 10 deg but from memory (if I can trust that anymore) it already had a little distortion in the tube itself. But the Corvette axles are much larger dia at 2-1/2 inches also.
ERA 782 Running
