Old 05-13-2002, 10:07 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Definitely go with the good meter and check it. When I put a new harness in my truck I also put in some new guages and was showing 14.5 at idle and just under 16 as soon as I touched the gas pedal. Checked with a good meter at the alternator and the fuse block and found out I was only getting about 13.2 at idle and 14.5 after that. Which is what it should be.
Also as a side note: I checked the guage and if you remove the light fixture I could see an adjuster block inside the guage. Tweaked that and now it reads what it should.
