Old 07-02-2016, 04:57 PM
Joe's Garage Joe's Garage is offline
Originally Posted by Flygirl View Post
Thanks, guys! It makes sense now. Never considered the cam profile as a contributor, or driveline lash, or PIO either.
And y'all are right, keeping the rpms up just a little helps a lot. The worse case I experienced was probably closer to idle, definitely below 10mph. And in both cases, only in first gear at low speeds with very little throttle opening.
It doesn't really bother me. But experiencing it again had me thinking there was something more seriously wrong that was causing the problem.
The Porsche could be pretty bad, actually, but in that case (come to think of it) it was induced by PIO via the throttle.
Many thanks!
Natalie
I take it your are convinced you are not just lugging the motor, any manual will lug if your RPM is too low to handle the gearing.
