Old 05-13-2002, 10:21 PM
Whaler Whaler is offline
Mike I have no brown wire
And whats worse is that even though this is a painless kit, I have no numbers like you refer to.
All I have are these 5 wires which are labeled clearly on each wire
-IGN SW start.....Purple 12 ga.
-IGN SW Coil.....Pink 14 ga......
-Ign SW Acc....Orange 12 ga.
-Ign SW Power.....Red 12 ga.
-a Smaller Red wire, unmarked (is from MSD to a switched source)......
I have seen the instructions online at painless which show wire numbers in the numbers ranges as you have mentioned, but i don't have those on my wires or in my wiring instructions.
I have a 13 page handout that may even be a photocopy from my builder.
First two pages are instructions on wiring in general
Page 3 is a "Number list of all wires" in the kit
Page4 is a "checklist for hot leads"
Page5 is a "wiring chart" which is actually a breakdown listing different areas of the car
Engine compartment wiring,Instrument panel wiring, Ignition connectors,turn signal connector, Dimmer switch connector, tail wiring.
The wiring chart shows wire list number, gauge,origination,destination.
Page 5 thru 11 shows the cheesy pictorials, I won't call them schematics. By areas as above
So does this sound like a painless to you folks??
How can something so simple be so confusing.
Tim
