  #31 (permalink)
Old 07-02-2016, 09:05 PM
SNClocks SNClocks is offline
Cobra Make, Engine: Looking for a SP Daytona
Thank you for the comments. Joe's Garage - I would think if I was lugging it, it would get worse when I added throttle - nope, it smooths out and pulls. From 1200 rpm, no problem. But, light throttle at 1800 - bucks.
Lippy - Thank you for the guidance on how to tell if the IFR's are sized reasonably. I plan to first verify timing is to build spec, then check out the 4 idle screw settings. Build sheet shows 16 deg BTDC at 900 RPM, 32 at 3000.
Stephen
