Old 05-14-2002, 12:01 AM
Snake Snake is offline
Post DV
I guess once the doors are set, and the rear of the car is set...you then tap and attach the front end?
When you cut out the door web....how much do you leave? I'll explain better...do you sand down the edge area flush to the inside body...when I was drilling and tapping...the edge of the inside was interferring with the chuck of the drill....I thought that you would leave about a 1/4 of an inch or so....for when you put the insulation and the carpet in, it would then be flush with the inside....is this right...or should I grind down the inside of the door flush to the inside body...don't know if this makes sence to you.
Thanks.
Snake.
