Old 07-05-2016, 09:21 AM
Dale McBain Dale McBain is offline
Default Rtts 2016
Tim,
Vapor lock? Ever had that problem before? If it persists you might try wrapping the fuel line with aluminum foil to reflect the heat. Also check your fuel filter I had a problem that I thought was vapor lock until it got so bad I new it could not be vapor lock. Turned out to be the fuel filter.
Dale
