Old 07-09-2016, 08:45 AM
Fordzilla's Avatar
Fordzilla Fordzilla is offline
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Don't know if you ruled this out (didn't read through all the posts) but is good info: I had a break-up of ignition in my FE starting at about 4000 rpm. Visual inspection of cap, rotor, magnetic trigger showed nothing wrong. I ordered new parts & when taking out the magnetic trigger discovered that the magnets were actually 2 magnets, one in front of the other. The magnet you could not see was cracked in half. all there but cracked so when you removed it, you had 2 separate pieces. I replaced the magnetic trigger & no more high rpm breakup.
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
