Old 07-10-2016, 06:57 AM
SFSDFGT SFSDFGT is offline
Cobra Make, Engine: CSX 4145, aluminum body and Shelby aluminum FE stroker
Default CSX 4145, finally getting sorted out
Hello all,
I bought a CSX 4000 series car a couple of years ago. Some may recall this thread: Ebay Alumin CSX 4000 series on Ebay
Well, I LOVE to drive the car, but I've had various gremlins pop up, from a fan relay burning up, to rocker arm shaft bolts breaking, to the spitting rear differential issue. I've thoroughly enjoyed fixing these (and many other) issues myself, but lately the car has been running terrible. Coughing, sputtering, backfiring, won't idle. I finally had a chance to spend some time with it yesterday, and tore into the carb, and found it was plugged up in multiple areas, with what I assume is debris from a crumbling fuel cell bladder. Reassembled things, fired it up- BEAUTIFUL. Clean idle, test ride went perfectly for about 3 miles, and then same symptoms as before started to return, as more crap already found its way to the carb. So then I start looking around for the fuel filter... NO FUEL FILTER anywhere, as far as I can tell.
So anyway, I have a message in to Mickmate about either converting my fuel cell into a fuel tank, vs just replacing it with an aluminum tank he stocks.
But, and here is where you all come in, I figure that now is also the time to address some "issues" with the cobra that were mentioned in my introductory thread. I am going to have my trusted restoration shop handle all of these things, but they aren't cobra experts. I know that my fuel lines shouldn't be the fancy braided lines with anodized -AN fittings. Same for the oil cooler lines in the front. My engine seems to do just fine with just a breather and no puke tank, so since that is how mine was built apparently, I am going to leave that. However, mine also only has the front two pusher fans, which aren't really adequate, so I would like to add a puller fan. And I will FINALLY replace my crappy BFG tires with billboard Goodyears.
All of the other cosmetic stuff has been addressed. I had the strange-looking meatballs/numbers removed, and the paint, interior, and engine all cleaned up beautifully with a thorough detailing.
Any other thoughts as to glaring issues to address? I know some of you had mentioned in that thread that I should have quick-jacks, but for some reason it really doesn't bother me that I just have the over-rider bumperettes, and they sure have come in handy several times for pushing the car around when it is incapacitated.
Thank you in advance for any time/thought given to this.
