Old 07-10-2016, 12:00 PM
moore_rb's Avatar
moore_rb moore_rb is offline
Cobra Make, Engine: All original, with Chevy engine since 1964
The "self learn" is a trial to make tuning easier, but what I hear from engine builders and seasoned vets of the old school guys, is, they don't have the system worked out yet, as they still have problems to be worked out. That's why so many give up and go back to carbs.
Depends on what kind of "self learning" system we are talking about.
With some of these new, self learning throttle body injection systems... I agree- They are buggy (I think TBI sucks in general for performance applications, to be honest- If you want to run a cheap carburetor style intake manifold, then you might as well just run a carb on top of it... )
But MAF/MAP combination port injection systems are fairly well established, and still offer the most EFI benefits for the cost (JMHO).
Olddog- Great post about wide band versus narrow band tuning - agree that it is all more about marketting BS than actual performance.
Your idea about integrating the MAFS into the 8-stack horns is one I have thought of as well - But I was thinking that the best way to do it would be to string an air flow meter across each air horn, and then program a chip to aggregate the signals from the 8 sensors and blend them into one air flow curve to feed the PCM, as opposed to using the signal from just one throttle body and then assuming that the other 7 are flowing the same amount of air... probably 6 of one, half dozen of the other- Your way would be easier (and cheaper)
But like you said- it's pretty much just a brain exercise, and would only add more cost to these outrageous $10,000 systems, so unlikely to ever go anywhere.
And like you also said- every year, more and more guys are running these systems - Eventually, the single carb look is going to be the most exotic looking
- Robert
