Old 07-11-2016, 06:26 PM
Cobra #3170 Cobra #3170 is offline
Default GT intake
Originally Posted by SFSDFGT View Post
Nice driving. What are you using for the intake setup for your Whipple? The GT Guys cold air kit? Something else custom? Or just the factory airbox?
Thank you, I made up a spray bar for the intercooler and designed a solid state timer that would turn it on for 5 to 20 seconds every minute depending on outside temp. I used a motor home washer bottle mounted in the front compartment filled with distilled water. That gives me 15 TO 20 minutes of track time. Running 26.5 psi with 105 unleaded. Factory air box with intake support,
The big problem is the blower heating intake air.
Just as I chicken lift going into 1 it is 194 mph and a little over 150 under the bridge, really stout acceleration for a non turbo car. I also have AP rotors, Carbotech pads and spring rates roughly 2 times higher than stock.
