Old 07-11-2016, 06:48 PM
SFSDFGT SFSDFGT is offline
Cobra Make & Engine: CSX 4145, aluminum body and Shelby aluminum FE stroker
Originally Posted by Cobra #3170 View Post
Thank you, I made up a spray bar for the intercooler and designed a solid state timer that would turn it on for 5 to 20 seconds every minute depending on outside temp. I used a motor home washer bottle mounted in the front compartment filled with distilled water. That gives me 15 TO 20 minutes of track time. Running 26.5 psi with 105 unleaded. Factory air box with intake support,
The big problem is the blower heating intake air.
Just as I chicken lift going into 1 it is 194 mph and a little over 150 under the bridge, really stout acceleration for a non turbo car. I also have AP rotors, Carbotech pads and spring rates roughly 2 times higher than stock.
I am surprised that your factory airbox is sufficient to flow enough air to support that kind of boost & power. I just put a 4.0L Whipple on my GT, and have been figuring out how to have my local fabricator make a better intake setup, similar to the GT Guys, only better. So many people have said that the factory airbox is a major power limiter once you go Whipple. People have told me that they picked up anywhere from 2-4 psi of boost just by either drilling holes in the bottom of their airbox, or going with a dual-conical filter/dual snorkel type setup.
