Old 07-12-2016, 12:27 PM
LMH's Avatar
LMH LMH is offline
Originally Posted by Akimbeau View Post
I'm looking at a 6 piston kit from Wilwood (140-10738) that has 12.19" rotors and am planning on the Trigo 5 pin hub adapters. Is this the same as what you are using? What spindles does the Hurricane use?
Kim
Close to what I'm using except I have Dynalites. No fitment issues. Hurricane spindles are Mustang II. It took some doing but I have zero offset hubs so the track width isn't increased. Yours may be different and offset may not be an issue for you. Just note what Wilwood says about it and make sure it works before ordering.
Alba gu brąth
