Originally Posted by Gary(SF)
I have heard that before, but my 521 with Weber 48 IDA's pulls strong to the redline. Go figure.
Great to know! Its always perplexed me how 8 trumpets theoretically can't supply enough air for each cylinder when compared to a single carb
If you don't mind kindly sharing please:
What are your cam specs?
Hydraulic or solid rollers?
and Rpm red line?
Thx
Originally Posted by FUNFER2
Can a cam be too big, that you have little vacuum, meaning do we need vacuum to run the system properly ?
Are there any other specs of the engine that will screw up the working of this type of injection, thus the engine will not run well ?
Any special engine build needs for this injection ?
My understanding is a wide lsa is required to limit reversion, and the more vacuum the better the end result. I'm no expert. I defer to greater minds for info on this.
