Thread: electric choke
Old 07-13-2016, 11:52 AM
Phill Pollard Phill Pollard is offline
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
I would probably not try to wire it directly to the alternator.
The/An advantage to using the alternator as a power source is, the bi-metalic spring doesn't heat up until the car is RUNNING as opposed to simply with the KEY ON (Engine Off).
A direct connection could result in the choke opening with the car sitting, Key On/Engine Off (KOEO).
Bottom line is, it's a personal choice. I personally would probably use the ignition as a power source but I would also fuse it between the resistor (or coil Pos (+) if I used it) and the choke element.
Better safe than sorry,
Phill Pollard
