  #23 (permalink)
Old 07-16-2016, 12:55 PM
joyridin''s Avatar
joyridin' joyridin' is offline
When I was building my CMC, I used a 93 Mustang 8.8 and converted it to 5 lug using Ranger axles. I got rear caliper mounts from Forte and added the 11.65" Cobra rear disk brakes. If you use the 94 and newer unit, it is 1.5" wider (if I recall) due to the anti-lock brake rings on the axles.
I think I then had it narrowed a few inches on each side and used Moser rear axles to get a wider tire under the rear.
