Old 07-17-2016, 08:00 AM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
My O2 sensor is only on one side - the passenger side. So, if it is not firing, it would be on the driver's side.
I don't think it is cross fire. I've re-routed the wires multiple times. I've ran the motor in the dark and don't see any sparking.
Pre-ignition - maybe. The cam isn't that big and I only have 9.5 to 1 static compression so I don't think my dynamic compression is very high. I'll have to study more about this and calculate my dynamic compression.
Valve float: I just got a valve spring compressor. I'm going to check the springs. There aren't any obviously broken springs but I may have a weak or damaged spring.
Edit: Dynamic compression 8.76:1
