Old 07-17-2016, 11:47 AM
blykins blykins is offline
Originally Posted by Texasdoc View Post
My Cam card doesn't list advertised timing events, only .050.
I've got Gross valve lift, valve duration @ .006, valve duration at .050, valve timing at .050, lobe lift, and lobe separation.
Edit: Hang on, the second part of the program looks like it will calculate the advertised closing based on the advertised numbers and centerline/separation numbers....
Duration at .006" is advertised duration for a hydraulic cam. You always use advertised duration when calculating DCR.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
