Old 07-17-2016, 01:17 PM
Phill Pollard Phill Pollard is offline
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
Originally Posted by lastdime View Post
I just rebuilt my Super Cobra Jet 460 but am having trouble with the carburetor gasket not sealing. When I spray carburetor starter fluid at the base of the carburetor the engine revs. Sure sign that the gasket isn't sealing. I tried two different gaskets, checked to ensure the surfaces of the Quick Fuel carburetor and Toker II manifold are clean, but still no luck. I don't dare tighten the bolts anymore for fear of striping them. Any suggestions?
Man, I see a lot of suggestions being floated about but before jumping to conclusions, I suggest you go back to *basics* and check the mating (mounting) surface for flatness FIRST.
If you don't already have a straight-edge, get one and use it to confirm both surfaces (intake manifold AND carburetor) are true. I have one that's about 12" long that I got from my Snap On man many years ago. I'd bet you can probably find a inexpensive one (the Snap On item is NOT cheap) at Harbor Freight or some likewise company.
It's easy using a straight-edge and a flashlight. If you confirm a gap with a light, use a feeler gauge to see how much of a void you have and go from there.
If both surfaces are true and you still get a change in idle quality or speed, it could be a shaft issue or a open vacuum port you might not be able to see.
Good luck,
Phill
