Old 07-20-2016, 10:11 AM
cycleguy55's Avatar
Originally Posted by mjhcobra View Post
Hi Guys,
I am tired of my throttle cable hanging up and have decided to change to the mechanical linkage.
1. Where can I purchase the mechanical linkage for a 428 FE single carb engine?
2. Pics of how the set up is installed will help. My EM pedal assembly has a cable that is routed thru the top of the foot box to the carb. How is the manual linkage connected to the throttle pedal?
Any info will help.
Martin
Here are a couple of links illustrating how the mechanical linkage works. You'll see 1 in the first link, and 2 different systems in the second link - figure out which will work best in your car and run with that:
Engine, transmission and brake stuff
ACCELERATOR PEDAL AND LINKAGE
All things being equal, I'd go with the linkage in the first diagram but, then again, I'm not familiar with E-M and which would work best. Perhaps someone with E-M experience can lend their informed opinion.
BTW - have you posted this in the E-M forum (http://www.clubcobra.com/forums/ever...k-julie-brett/)? It does appear to be a marque-specific question.
Brian
