Old 07-20-2016, 12:54 PM
tamanaco's Avatar
tamanaco tamanaco is offline
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Originally Posted by Grey 65 View Post
The entire suspension is without rubber or poly as I want to eliminate as much deflection as possible. This makes the handling much more predictable and allows me to pull higher G's... We pull around 1.3 G's when turning and around 1 G accelerating and braking. And we change directions a lot. An autocross is basically a road course without the straits....
The poly diff mounts are there as I want a weee little bit of deflection there so as to slow down the shock load transfer to the ground under load and back to the diff when you release the load.
Kevin....
tried the autocrossing in my BDR, I need p/s and a quicker ration rack for me to do it. Nice numbers on the "G" forces! and thanks for the Poly diff mount explaination.
Bill
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
