Old 07-23-2016, 05:28 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you are referring to a trunk mounted tank with nozzles piped to the engine compartment, the manual actuator that is located on the dash already has a safety pin. The tank also has a 2nd pin but it is removed after the cable linkage is installed. I can send you photos of my install if you like. The manufacturer is Safecraft, they have a large selection.
SPFWiringDiagrams@Comcast.net
