07-23-2016, 05:55 PM
Cobra Make, Engine: SPF#0760
Did you look to see if the center contact on the rotor is making good contact with the cap center electrode?
Also, somewhere there was a thread on distributor phasing....
Ground and power connectors/wires all in good condition.
If you source the ignition key-on power from the ignition switch, perhaps try a jumper and temporarily power it from a good known source. Ignition switch could be on the fritz...
Easy enough to do a resistance test on the wires...
SPFWiringDiagrams@Comcast.net
