  #31 (permalink)
Old 07-24-2016, 01:39 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Neutral
A hydraulic roller will be less tolerant of higher spring pressures, but guys seem to want high pressure with both double springs. Either way, what are the things you can to them and not to bend, snap and even float the valve at high RPM's ?
What are the safe guards for the FE, including not floating valves ?
Should just put a Chevy in, a lot cheaper & easier.
Regards,
Kevin
