Old 07-26-2016, 07:31 PM
stallion112's Avatar
stallion112 stallion112 is offline
Cobra Make, Engine: Kellison Stallion, 429 SCJ,
Default Summit racing HEI distributor
I was considering installing a Summit Racing HEI distributor into my '71 429 SCJ. The p/n is SUM 850025. I was told by Summit that the height from the block to the top of the cap is 9-3/4 inches. They did not have the dimensions for the diameter.
I have an expansion tank right in front of the current Ford distributor with not much room to spare. Does anyone know the diameter over the vacuum advance as well as on the other side where the harness connects?
I have an aftermarket intake that has the thermostat on the passenger side so I'm not concerned about the upper radiator hose like their instructions warn you about.
Stallion112
