Old 07-26-2016, 07:54 PM
Rawkkrawler's Avatar
Rawkkrawler Rawkkrawler is offline
Cobra Make, Engine: Everett Morrison
Originally Posted by Blas View Post
Did you look to see if the center contact on the rotor is making good contact with the cap center electrode?
Also, somewhere there was a thread on distributor phasing....
Ground and power connectors/wires all in good condition.
If you source the ignition key-on power from the ignition switch, perhaps try a jumper and temporarily power it from a good known source. Ignition switch could be on the fritz...
Easy enough to do a resistance test on the wires...
I think i have in narrowed down to the distributor. It has a bad rev limit dip switch and the center conductor is a little worn. Swapping in a new motor as we speak so i'm going to stop troubleshooting.
Thanks for the suggestions!
Mike D
Tampa Fl
