Old 05-14-2002, 09:55 PM
BT SNAKE's Avatar
BT SNAKE BT SNAKE is offline
Cobra Make, Engine: Midstates Cobra, RFGT40
Thumbs up
Leroy,
I just finished spraying my GT40 with a HVLP Sata gun.
Frankly I see about the same amount of over spray from
it as I do my old Binks 7 gun. The HVLP works really well
and I like the gravity fed cup much better. It seems to have
a better spray adjustment pattern than the Binks. The
best tip I can give you is to keep the gun clean. Any
contamination what so ever will result in disaster. I have
two tips for the gun. A 1.4MM and a 2.2. The 2.2 is mostly
used for heavy primer sealers.
Remember to do all the prep work cause base coat hides
no blimishes. If it ain't right you will see it in the final
product.
Hersh
