Old 07-27-2016, 02:03 PM
jhv48 jhv48 is offline
If you want to do the job yourself without removing the heads, go to youtube and watch a couple of videos. Key to success is preventing a valve from falling into the cylinder once the springs are removed. Buy a good valve spring compressor tool and once you have the correct parts, R&R should only take half a day. While you're at it, pull the pushrods and make sure they're still straight and not damaged on the ends.
Jim
