Old 07-28-2016, 11:01 AM
snapier's Avatar
snapier snapier is offline
Cobra Make, Engine: Superformance ford v8
Default Ignition problem
Ignition problem
have a SPF 1400 and went to start the car. Would not start just cranked over and over. Just went on a ride a few days ago.
Check gas OK. Not getting spark from coil to distributor Did a ohms check on coil OK.
Hooked up a test plug light to form coil to distributor and would not spark while cranking engine. I did notice that I would get spark sometimes as I turned the key off. Could this be the ignition module (Duraspark)?
I change the Duraspark ignition module. I replaced the magnetic pickup in the distributor. I replaced the distributor cap and rotor.
Any one have any ideas.
Found the problem (WOW) both Duraspark ignition module and the MSD distributor magnetic pickup where both bad at the same time...
