Old 05-15-2002, 12:18 AM
Snake Snake is offline
Post DV
Thanks DV! I don't have any bumpe stops for the hood...CR didn't have any either? Finding them here is impossable. I think the front right side is low...where the side pipes come out of the body seems to be touching the pipes. The drivers side has an 1" or so before the pipe would touch...I tought of opening the space a little more....but your way my be better...it's just the part about lifting the body up that makes me wonder what I should do...I think if I did that the hood would need to have a spacer under the hood bracket that is attached to the hood? Also wouldn't that make the right side fender have a higher spacer from the tier to the lip of the fender...Does this make any sence to you?
Snake.
