Old 08-01-2016, 06:00 PM
Trickycoupe's Avatar
Trickycoupe Trickycoupe is offline
I believe if you use the davies craig pump controller, you do not use a thermostat. The controller cycles coolant at a rate that allows correct warm up and cooling functions.
If the thermostat is fitted it will cause both a restriction and the controller to fight against it when trying to control coolant flow.
Ricky
RF GT40, Ralt RT5
