  #22 (permalink)
Old 08-02-2016, 05:22 AM
Dimis's Avatar
Dimis Dimis is offline
Originally Posted by 14adrnln View Post
Has anyone seen or tried the Hero single post 2.5T portable lift? I know it only lifts to 1.75m but looks like it could be a good option to move out of the way once the cobra build is finished and the space is turned into my car collection museum.
I've seen these used, not sure it was the same brand, problem is where to store them when not in use. If you have the space, sure go for it.
Originally Posted by Ezakimak View Post
I would dearly love a hoist in the future.
My shed at the moment is 2400 below the rafters. 2500 between the rafters. So if I set it in the centre I could get the roof section to rise up between the two rafters. No going to leave much room though.
Will probably end up with a scissors lift table in the floor
I suffer similar circumstances. Low roof line and limited space.
My dream garage would look something like this:
But in lieu of having the cash and gumption to pull that off, and while I'm dreaming, I've been eyeing off one of these in-ground versions. http://powerrex.net.au/brochures/Powerrex_SL34DX.pdf
Similar to this:
But with this type of lift for more access under the cobra.
I love the way you can essentially store it away without issue (ie: buried).
I'm trying to convince myself to justify the spend but if I'm honest I'm pretty hopeless with any "real" automotive work. I figure maybe, just maybe, I could convince the myself and the wife it's an in-ground a table, it's more likely to see use that way.
