Old 05-15-2002, 02:41 PM
DAVID GAGNARD's Avatar
Clois;
Yes you can wet sand the "color coat". We did in the shop but only when neccessary as when we found "trash" or had a run or sag in the color coat. Same as sanding the clear,but we usually used 1500 or higher number sand paper,sanding very lightly,you do not have to sand the hell out of it like you sometimes do for clear....But as always, check with the paint manufacter for their recomendations for that specific product.....
Hated to have to wet sand the color cause now you usually have to remask evrything as the paper gets all wet and falls apart and you have to make sure it is completely dry before spraying clear,especially under and around moldgings and such. Water droplets have a way of hiding and then when you start spraying clear,they appear from nowhere and make nice little tiny bubbles in your clear....
David
DAVID GAGNARD
