Old 09-04-2016, 05:00 PM
Modena's Avatar
Modena Modena is offline
Originally Posted by GH427 View Post
Hi Modena, interested how you measured up the positions of the holes for the quick jacks before you drilled them.
George
Hi, the "bolt" is currently a piece of threaded rod which I'm going to replace with a socket head cap screw. I bolted on the threaded rod inside and used it to mark the inside of the body, then drilled a pilot hole from the inside and then used the hole saw from the outside.
Ben in AU
