Old 09-09-2016, 08:14 AM
rbgray1's Avatar
rbgray1 rbgray1 is offline
Redhawk,
You're welcome. It's good to share ideas and fixes when we both are doing very similar things to our cars. I know I'll like the final outcome as well, just want to confirm that some of these engineering changes in the parts are for the better and don't cause me headaches down the road. Hopefully I will have pictures in the next few days of all the new suspension, coilovers, and Wilwood brakes on the car. I figured out a great easy way to convert the rear to QA1 coilovers with some very simple and strong brackets I'm welding on the upper frame in the rear and changing the lower shock mount on the rear. I'll send pics when done.
BTW, if you hit a Kardashian.....make sure you put your car in reverse and do it at least 4 more times......then repeat!
